agallant80
Thread starter- Joined
- Oct 25, 2010
- 2,328
How often do you grease trailer bearings? I have Zurk fittings. How often should I give them a squirt or grease?
So can someone tell me more about these oil bath things? My trailer goes between salt and fresh water.
I just grease when i change bearings, every 20 year or so.
The trick is to keep the Wheel center and bearings abowe the water![]()
Oil hubs work well until.........your oil seal fails while you are at highway speed, you can have a total loss of lubricant very quickly, burn up your bearings, ruin the hub, the axle, or both. You probably will not notice you have a problem until you see smoke. If your luck is really bad you may have a hub/wheel assembly come off while going down the road.
You come on over here and show me how to do that on these shallow ramps we have.![]()
ipods are what ipeas come in.ipod???? Whats one of those????
