The livewell compartment on my new boat only has a pump that pumps the water from the compartment, no way to fill it or circulate/aerate the water. This is obviously not the way it was from the factor as there is a switch on the dash marked "aerator". I am going to be adding another thru-hull fitting with spray head, and removing the existing pump and adding a removable stand pipe. The compartment measures 29"x29"x15". I am thinking about cutting off the stand pipe so the water can only get 10" deep, that should give me about 36 gallons. Is 10" is going to be deep enough for a decent sized fish?
The deck is a fiberglass cap that is set over wood stringers, and the tank is a molded fiberglass unit. There is a gap along the top where the livewell meets the deck that I need to seal off to prevent sloshing water from getting on the wood and saturating it. What is the best way to seal this off? The picture isn't the best, I had to hold my hand inside the livewell and shoot under the decking blind to try and capture the gap. It looks way bigger in the picture than it actually is
