Grumpy Bear
- Joined
- Aug 23, 2014
- 58
While I have the powerhead on my 74 Merc 500 50hp cracked open, I thought I would replace the seals and bearings in the upper and lower end caps of the crankshaft. I got the lower cap off just fine, but I'll be a son of a gun if I can figure out how to get the bearing out of the thing (see pics). So, I have 3 questions:
(1) Is there some special tool I need to get this off? (I'd hate to buy a tool to use once, but hey...)
(2) When I reinstall, I assume the bearing needs to be installed in the end cap before putting it back on the crank? I've seen other engines where the bearing is installed on the crank (after heating it) then the end cap just slides over it, but I don't think this one is installed or removed that way. Advice?
(3) I assume I'll need to use Merc's specific flywheel puller to get to the top bearing?
Thanks in advance for your help!
Kevin
Kevin
