Re: How the eff do i get this tilt tube out!!!!
Hanging on a hoist or laying flat on its back... the weight factor is non existent and the tube should slide out with very little effort.
Yours in all probability is frozen tight due to a corrosion factor within the transom brackets. If this is the case, use a hand held propane torch at those transom brackets at the steering/tilt tube point to expand the aluminum of the brackets to help free the tube.
