How to adjust shift cable - 140 i/o
farrellmh
Hey .. need help adjusting the shift cable on my 1985 3.0 140 merc I/O ..... before it would grind untill you pushed it farther down.. then clunk in a gooo.. and take off... my father says that i should be able to shift into gear.. and not more lol.. so the cable is new.. how to do i adjust to to shift nicceeee
thanks
Mike
farrellmh
Re: How to adjust shift cable - 140 i/o
SORRY ment to say " CLunk in AND goooo "" sry
Thanks
Mike
Limited-Time
You NEED the manual or a link to it. The adjustment procedure is very specific, there are measurements that have to be correct in order for it to shift in AND out of gear correctly.
Gary H NC
Also all the grinding before could have killed the gears in the outdrive!:%
It should go into gear at idle without much of a clunk.
farrellmh
thanks alot guys... now i just have to wait for it to stop snowing again... so i can get out there and try and fire it up for the first time this season ..
any other tips on the first season start up ??
thanks
MIke
