mercurymang
Thread starter- Joined
- Jul 14, 2012
- 853
'75 Merc 650 (triple)
As you may or may not know, I did quite a bit of work over the winter to my motor and it's running great now. One of the things I did not do (which I should have done) was change the timing belt. It seems to have quite a bit of play and I don't want it to snap out on the water.
My question is what it the best way to change it out. I had it on and off a couple of times over the winter but I'm not sure it's the correct way to do it. When I re-installed it, i fed it up under the stator with the flywheel off and then fit it around the timing gear on the flywheel. Then I carefully installed the flywheel with the timing belt on it. It was a little hard to get it to go on as there was barely any clearance between the belt and the end cap. As I could see it, there was no other way to do it except maybe to remove the bolts on the flywheel leaving the center portion of it attached to the crank, installing the belt, then re-attaching it.
Can anyone tell me the correct way of doing it?
