how to chck timing
how do you set the timing on a 1989 200 mariner is there a high rpm seting and a low idle im lost here i see the marks on top of fly wheel
Ware5150
Re: how to chck timing
Yes, you really need a manual to help guide you but here are the basics. Find Top Dead Center. Set the pointer. Pull all of the plugs out except plug #1. Reinstall 2-4/6 and ground if system has coil packs. With the throttle on idle check for your primary timing point buy cranking the motor and using a timing light. Disconnect the throttle linkage and place throttle to wide open throttle check again for timing advance setting.
Here are the basics but you need the manual to know how to make the proper adjustments.
