Re: How to check timing advance
First thing you need is the timing curve, so you know what you should be looking for. The next thing that will help is a proper advance timing light. That will allow you to 'dial up' the timing advance so it will be easier to read than guessing where the timing is (more on that in a second)...
Here's what your timing curve should look like:
From that we can see that, for example, at 2000rpm the advance should be 13? (above the initial advance, which should be 8?BTDC. So total advance at 2000rpm should be 21?).... As the timing indicator on the front of the engine doesn't go you that far you have 2 choices. You can try and mark the pulley and 'guess' where the timing actual is, or you can use an advance timing light, dial in 21? and see the timing mark at the 0 indicator...
Hope that's clear enough...
Chris.....
(and you also now have your timing curve
