How to Connect Rope to Tube and Boat
WVboater
A complete newbie question here, folks. We have a tube and a 60 ft. 5/8" 16 strand rope and need advice on how to make the connections with the rope on both ends (tube and boat). Is there specifice hardware to use?? The Airhead rope has loops at both ends. Connection to boat will be to a tow ring mounted on the swim platform (I don't need criticism on the location - just the how-to on the connection). All help appreciated since Dad does not want to get on the water with DD's and look like a fool when expected to start pulling them.
WVboater
jevery
Re: How to Connect Rope to Tube and Boat
If your tow ring looks like this
http://www.iboats.com/Seadog_Transo...07405665--**********.786040498--view_id.39715
Simply hook the loop over the ?finger? then wrap the loop around the finger once to increase contact area, (will prevent the loop from wearing prematurely at a single point)
If your towable has a quick connect like on the end of this
http://www.overtons.com/modperl/pro...ies-Towables-Tubes&aID=3I&merchID=1009&r=view
push the loop through the hole then hook the loop on the two hooks. If it doesn?t have a quick connect then get the above item for the rope to tube connection.
WVboater
Thanks for the info.
WVboater
wcsparky05
i had this same question last year. i could tell you, but knots are easier with step-by-step pics. www.wikipedia.com. don't tow tubes from your tower; you probably knew that but just trying to help! :)
