FOuR BuOYS
Thread starter- Joined
- May 11, 2008
- 20
I have two bilge pumps(500gph each). One is at the very back of my bilge under the motor and the other is in front of my motor. The float switch is about half way between. The wiring is no problem, I have figured that out.
I am just not sure if I should connect the outputs from both pumps into a common throughhole. The connections would be made close to the throughhole. Or should the connection be made on the floor. Or should I have a throughhote for each pump?? Installing a second throoughhole is a way bigger job.
Thanks
Thanks
