how to decarb 200 oceanpro
junior1113
want to do a decarb and unsure of the process thanx
tashasdaddy
Re: how to decarb 200 oceanpro
easiest way is if you have the schrader valve on the primer. get the BRP Engine Tune, with the hose that attaches to the schrader valve(bicycle pump valve).
junior1113
c if i get this right hook that up and start motor pump some in and dont let it stall then shut off and then what? and how much and how long ? does this help an engine and could i pick up maybee 50 rpms if my comp. goes up?
thanks tasha
tashasdaddy
follow the directions on the can of Engine Tuner.
