How to detach crankcase on 1976 25HP Johnson
andreipou
Hello,
I have problem with disassembling my 1976 25 HP Sea Horse (model#25R76E).
I can not detach crankcase from the head. I removed 2 pins and all the screws and it looks like it is held just by sealant. I tried to tap with wood block and heavy hammer and it did not work. I am afraid to put to much effort and break it.
Is there any trick?
Thanks.
Chinewalker
Re: How to detach crankcase on 1976 25HP Johnson
Did you get all the bolts? There are eight (I think) small bolts around the perimeter, and six larger ones in a rectangle on either side of the crankshaft (some might be studded, I can't recall).
Once they're all out I usually do the wood block thing...
- Scott
andreipou
There are only seven hex bolts. Original repair manual also says 7.
I tried hit on crancshaft with hammer with wood block but it did not work.
I am afraid to beak it.
andreipou
There are also 2 guiding pins...
