How To Determine If Motor Is 305 Or 350
jws123
I am going to look at a parts boat saturday Id be buying it for just the motor dumping the rest the guy does not know if its a 305 or a 350 and says the serial number on bellhousing isnt there. So how exactly can i tell if its a 305 or a 350? Hoping its a 350 below is pic of motor.
Scott06
Also can look at the label on ignition module will have the engine size on it. It is a 96 or newer vortec so boat likely had a repower at one point
So long as the module has not been replaced. Could be a 305 with 350 module
Port side will have displacement cast in the motor. Casting numbers on block may be easier to get to
jws123
Ok thanks messaged the seller trying to get the number stamped into the block before i go down to look at it.
QBhoy
Bit of a strange set up there. Not sure I’ve seen the gear oil tank sitting where yours is.
jws123
Yea and it doesn't look like there's anything in it?
My 1997 wellcraft had tank in that spot also yea it is empty the rest of the boat is basically **** only buying it for the trailer and motor since it runs good once i confirm its a 350 guy is selling it crazy cheap.
flashback
.,I see much better access for maintenance on several items that usually get nothing.that reman has some advantages.
tank1949
casting # should be on back near where bell housing connects. May be difficult to find with all the wires and hoses.
