Mark42
- Joined
- Oct 8, 2003
- 9,334
If you are thinking of using a gas spring to open a hatch, engine cover, etc and its a new application, this site has some great info that will help decide where to mount the struts and how to figure out the pounds of force needed.
Take a look at the "Standard Sizes" page, they are comparable to the typical offering from Whitecap and Attwood. Then using the Application chart, match the spring to the size and weight of the hatch, and also how you want it to act (hold closed, hold open, full swing support, etc)
http://www.gassprings.net/
http://www.gassprings.net/applications.html
The important part is for the open/closed length, and the lbs of force, where the pivot points are located on the hatch and frame.
