lakeaustinag
Thread starter- Joined
- May 18, 2010
- 7
My trailer lights weren't working on my older trailer so I decided to re-wire it this weekend. I wired it up and my turn signals and brake lights were working but not my running lights. I used the little plastic splice connectors but I'm not sure if I did them right. Do you have to strip the wire first before you put it in there and close the little snap? What else could be causing my running lights to not work? I checked my ground wire and it is securely bolted to the frame. it's an older trailer too if that helps. Thanks.
