Blue Crabber
Ensign
- Joined
- Apr 2, 2009
- 966
Hey Everyone! Been hanging around here for a while and picked up a used 1985 Sea Ray 30' Sedan Bridge boat that is my fixer-upper project. Here are some pictures of the boat for those that haven't seen it yet:
First part that I need some help with is replacing the wood coring in one of the engine hatch covers that also creates the cockpit flooring.
Here is a picture of the cockpit of the boat with the hatches up, but you can get the idea of how they work. All 3 hatches are leaning against the transom of the boat and you can just see the bottoms of them in the top of the picture.
Here is a picture of the topside of the hatch:
And here is a picture of the bottom side with most of the wood coring removed:
And a few more Pictures:
So here are my questions:
I know that I need to remove the rest of the wood. Do I also need to grind down the old lip as well?
If I leave the old lip, do I grind the coating down to bare fiberglass or how do I make the new fiberglass adhere?
When I replace the wood coring, do I just put a layer of epoxy onto the top of the hatch and then lay the wood in and clamp in place until it cures?
I have plenty of West Systems 105 epoxy and 207 Hardner that I will use to fiberglass this in place.
How many layers and of what type of fiberglass cloth do I use?
I know that this is a lot of questions as this is my first fiberglass project. I have watched some videos and read some threads, but thought I would ask here to get information related exactly to my project instead of making assumptions!
Thanks in advance for all of the replies and help guys, you rule!
