HOW TO FILL POWER TRIM ON 1982 50HP MARINER NO RESIVOR ON PUMP INSIDE OF BOAT CYLINDERS ON EACH SIDE OF MOTOR
SM FAB
HOW TO FILL POWER TRIM ON 1982 50 HP MARINER, NO RESIVOR ON PUMP INSIDE OF BOAT AND CYLINDERS ARE ON OUTSIDE ON EACH SIDE OF MOTOR
Welcome
No need to SHOUT at us
What's your motor serial number?
Looks like BWR1953 in post 7 has the answer
The trim pump is not part of the motor, it's mounted on the boat hull
Chris1956
If the pump is like the picture in post #7, the pump is self-bleeding. just fill it with ATF or 5W-30 motor oil, whatever it already has in it. The trim cylinders are not self-bleeding, however.
Give a pull on the gearcase and see if she moves a bit. If so, they must be bled.
