jrs_diesel
Thread starter- Joined
- Mar 3, 2010
- 552
I am rebuilding a what I think is a 70's vintage 6 HP long shaft Johnson. Here is my dilemma.
According to the ID tag on the transom bracket, it is a 6R77A, which tells me it's a 1977. A few problems with that though:
- The outboard is painted in Johnson green, except for the transom bracket which is white.
- The motor is of the LONGshaft variety, which tells me that the model number should read 6RL77A, not 6R77A.
-1977 is when Johnson switched to capacitive discharge (CD, called MagFlash I think). My engine has points ignition.
-1977 is when Johnson started painted their engines white, not green.
I do not know much of the prior history of the motor, other than it was attached to my sailboat (a Catalina 22). It has not been run in at least 10 years. It was run in salt/brackish waters, and not flushed out, as evidenced by some internal water passage corrosion.
Is there any other tags, stampings, or other ways to figure out what year this motor was made? Since I am rebuilding it, I want to make sure I buy the correct parts.
