northernmerc
Thread starter- Joined
- Apr 6, 2009
- 401
A friend borrowed my fishing boat and left it in the water at the dock with the motor damaged. He hadn't noticed the damage, but I immediately saw it after loading the boat on the trailer. It's a 30 hp Johnson, 2000 model year.
Uploaded with ImageShack.us
http://img545.imageshack.us/img545/3535/johnsonlowerunit30hp200.jpg
As you can see by the picture, part of the lower unit is broken off. Once I asked my friend about it, he mentioned that he hit a submerged vinyl/cloth barbecue cover. It seems that it wrapped around the prop until the motor stopped. Possibly the force of the jammed barbecue cover was enough to break the fin off the leg. Maybe the cover hooked on the aluminum thing that projects below that piece (above the prop) and broke the piece off.
It does not leak oil, and the motor runs again. But the lower unit looks terrible, and it will hurt resale value if I ever want to get rid of this motor.
The break is right through the bolt hole used to hold on that little aluminum fin that goes down above the prop. That piece is also missing.
The prop also sustained a lot of damage, with big chunks knocked out of it. But I fixed that. It also came back with lots of fishing line wrapped around the prop and inside the prop. The oil in the leg looked milky when I drained it, so I probably will have to replace the seal on the prop shaft.
I've wondered about welding in a piece of metal on the lower unit and then painting the repair. I have virtually no experience at welding aluminum, although I'm pretty good with steel. I have an AC/DC arc welder, a MIG welder, and an oxy-acetylene unit. Any advice on welding this? Rods or wire to use and fill material to replace the broken piece?
Or would it be better to look for a used lower unit? A new piece would cost more than the motor is worth.
