GSX455
Thread starter- Joined
- Aug 21, 2016
- 165
I tabbed with 1708 and it wet out great, I put 1 layer of CSM with isophthalic resin, let it cure. Came back today wiped the area with acetone, put 2nd layer of CSM followed by 1708. Had a few spots not wet out, white areas. Other areas were fine. It was warm out so the acetone flash off was complete. I rolled it out some more with a short nap roller, maybe try fiberglass rollers? Would it wet out better, maybe follow up in the evening so the acetone seeps into the cured polyester?
2nd question, the plywood stringer is glued 3/4" pieces (1.5" thick) and is about 1 foot shorter than the original stringer (see photo for original). Should cut out a notch and lengthen the stringer 1.5 feet. I realize a butt joint would offer no strength, but if I cut a 6" long notch and added 1.5 feet of 3/4" plywood it would be the same as the original length.
