How to flush/wash SX-M1?
lonewolf41
I have a SX-M1 drive that looks like it might have a little rust residue inside. There was a brown streak that came out with the drive oil (which looked new BTW). I took the shifter plate/panel off to replace the seal around the shifter piston as it was leaking during the vacuum test. The gears and everything looked OK, but there was a brown residue that came off when wiping a rag over the parts. This unit was in a salt environment so I would like to clean it as well as possible before using it. I have heard mention of flushing a drive, but did not find anything in the repair manual or anywhere else. Is there an official (or even unofficial) method for cleaning/flushing an outdrive. Just want to have it in as good of condition as possible before using it.
Thanks.
Ayuh,.... Fill it with fresh clean oil, 'n Run it,....
lonewolf41
So I don't need to "flush" it, just fill it back up and motor on? Change it again at the end of the year?
Thanks.
