How to fly in Norway?
Fjord Cruiser
Hi folks, :) I'm new here. I live in Norway, and I am blessed with probably one of the coolest boating places on the globe. I grew up in Canada where boating has a completely different use and meaning. Mariners and dealerships here are extremely conservative and way too badly informed about the things I would like to ask a North American forum.
Growing up in Canada, I ran a 13 foot Delta (I doubt any have heard it)The boat was light as a feather. I was running a 3 cyl 60 hp Evinrude without trim/tilt and without jackplate. The engine was mounted on the top holes, The tilt pin was set rediculously far out, and i ran an over the hub chopper propeller...to make a long story short, the bloody thing was a rocket, threw cool roostertails (I thing it's a blast to look back and see that), the chine walk was controllable, and when all came together...became an obsession to run the lakes at unreasonable speeds :D
Ok Ok...finally the question: I have just bought a Norwegian designed boat called With Dromedill 480 that is 15.7 feet long and weighs 573 lbs. This boat has a reputation for being able to handle gobbs of speed. (I'll try to show a picture under...) It has two...(i don't know how to describe it) hull extensions on either side of the engine that help with high speed stability. It's rated at a conservative 50 hp. I am buying a brand new Mercury 60 4 stroke, not the "big foot" (5500-6000rpm at WOT) to put on it. Even though it's heavier than what I ran in Canada, I would love to get this one up to dance as well. I'm hoping to run at about 40-50mph flat out. Wouldn't mind showing these vikings what a roostertail is... :D
I would love to feel a Chopper prop again, and this time I can afford a small jack-plate. What do you guys think of this combination. Would running this setup void Mercury's warranties? I wasn't planning to install a nosecone with lower water pickups (yet). How will my new Mercury react to using an over-the-hub propeller? I would consider a Chopper... do choppers fit Mercury? What size prop should I try first? What kind of jack-plate is best for this set up? How high up could I run the engine? How far under the keel should be the max height for my water pickups?
Any help from "the west side of the great pond" would be appreciated! :D
steelespike
Re: How to fly in Norway?
Thats a nice looking boat but doesn't look like a hull intended for speed.
The shape reminds me a little of a cape cod dory.Looks like it is intended to ride smooth in rough conditions.
mommicked
It looks alot like a sailboat hull from the rear.
Fjord Cruiser
It didn't look like much to me either the first time I saw it. I actually remember commenting that the rear shape of the hull resembles that of a sailboat. Then I saw one whip past me at around 45 mph in 8 inches of sharp chop. I didn't get a close look at the guys knuckles, but they didn't appear too white. ;) Don't be fooled by the conservative appearance of its topsides. It's true that the forward section of the hull can (thankfully) take a hell of a pounding and I put that to the test regularly as I live right by the North Sea where a quiet day occurs...to put it mildly...seldom. But when we duck into the quiet fjords it's a different matter. Open up the throttle, trim it so that the forward part gets slightly airbourne, and the boat gets up on it's "heels" (those two protruding sections of hull either side of the engine). It stays remarkably stable. Take a look at the hull blueprints I included in the original post. Check out this you tube clip of a 12 foot version of this hull with a 40 hp!!
http://www.youtube.com/watch?v=b1O8wfYaJCw&feature=player_detailpage
steelespike
Wow that does go and the bottom seems friendly and fast.Noticed just the slightest chinewalk in one pass.The way it rears up reminds me of my 18' crestliner(bare bones utility) 375lbs, with a 50 evinrude tiller.Goes fast but lays down a little to much to be real fast.I slide my but back against the transom and hit it and it rears up just like that but doesn't try to leap,out of the water.
I like the way yours settles down and scoots at just about perfect trim.
