How to get out of the sand
zach103
How do you get back out off the beach once your boats beached?? i saw the guy on ship shape tv sort of go side to side moving the engine side to side.. but not sure if thats the easiest way..
Shizzy
Ensign
Re: How to get out of the sand
my 14' alumacraft just needs a good shove and im 20 feet out.. :D
QC
This depends on a few things. When I am beached and preparing to leave, I usually push my boat off a little before I load, so she is not as stuck as she would be. Then, after I load, I have everyone go to the stern so that there is less weight on the bow. I usually put her in reverse and sit for a second just to see if there is a any movement at all. If there is, she'll come off as is, and I just wait. If not I run the steering back and forth to cause a little wiggle as you noted. If that still won't work I may use a little throttle. And then both the wiggle and the throttle.
There are many levels of "beached" so the above won't always work. On a shallow beach the drive and stern can both be on the sand, so I must work her off by hand some just to be able to start. If I load in that situation it would just be stupid. Also depends on what the water is doing. If you are getting a lot of wakes onto the stern, she is going to get more and more stuck. So another solution is to be very vigilant when you are on the beach to make sure she doesn't get really stuck. Sometimes we have to get multiple guys together to help each other literally lift off the stern.
Some will say the ultimate solution is never beach. Maybe, but where we boat beaching is part of our experience. If I didn't beach, I'd probably have to look for a new family . . .
ziggy
1st, turn on the blower. then i get unstuck off the beach so i'm floating... in shallow water i spin the boat 180*. from the stern i push out into waste deep water. then jump in over the stern. head for the helm and lower the drive. start and go.... i use variations of this depending on the conditions i'm in. it's most helpfull if someone else is onboard. i have them lower the drive while i'm pushing out into deeper water. this saves me one step that takes time. sometimes of which, i don't have depending on the circumstances...;)
tashasdaddy
the best way to beach. drop bow anchor, back toward beach, trim up, deploy stearn anchor.
the wrong way to beach:
QC
Agree ^^^^^ if there are swells, wakes, waves of any consideration. But people need to realise that there are different places with different modes of operation. I HATE literally beaching my boat, but I do it every trip, multiple times as this is the norm where we boat.
ziggy
i hate it too. but it's just too easy to do...
this is one of the beaches i go to. this is the morning after the 4th of july... any other time i'd be like yer pic QC......
NolaZach
For me its very simple because I have a 17' Jon Boat. I have taken it out twice and both times beached it. Definetly my next boat will be a bay boat but for now I like my little flat. I just beach and then use the motor or a stick to push off.
Yesterday I hit three stumps under water and got stuck on two, one of which was so bad the motor was out the water. Like I said I am very new to boating, and the water is always muddy here and sometimes you can't see 6" into the water. So thats another reason I am glad I have a jon boat because a fiberglass boat might have sunk.
Dakota47
just a little push is all it takes
Boatist
With my small 14 foot boat we sometimes beach bow in but not anywhere where there waves.
My 21 foot Crestliner we Back in and drop a bow anchor 50 to 100 feet out.
Then back into the beach with the kicker kill the motor and raise then step off on to the beach with a stern line.
Wife also pull the bow line tight and ties off.
With the 3/16 or 1/4 nylon stern line tie around a tree or bush or use a dog anchor
to dig a hole in the beach or bank and stick in a stick to tie to.
Now you can put boat anywhere you want it.
Bow anchor line is 3 strand nylon so has lots of stretch. Pull the boat out 5 feet or more and tie off.
If you what to get off and stay dry just pull on the stern line and step off.
To get back on pull on the stern line and step on.
The bow anchor line will pull the boat back out and soon as you let go of the stern line.
Can adjust at any time closer or farther out. Bigger waves loose the stern line some and tighten the bow line.
After you have done it twice you will find it better especially if you have a closed bow.
