jrs_diesel
Thread starter- Joined
- Mar 3, 2010
- 552
I have two seals that need to be removed since I am replacing all of the lower unit seals of my 72 Johnson 6 HP (in the middle of a rebuild of the entire motor). These 2 seals are located at the prop head bearing and the impeller housing retainer (pictured).
What is the best way to get these seals out, without destroying or damaging the parts? That impeller housing retainer is a very hard to find part.
Should I use a Dremel and cut them out and clean the bores or is there a better way?
Thanks
Thanks
