MercBlackMax1
Thread starter- Joined
- Dec 16, 2011
- 48
Hey just got my boat back in the drive way and took the heads of my pistons. They are fully lubed up and no rust + no scoring in the block and i have 120psi on all. I can turn the fly wheel and everything moves good untill i block at somepoint but i can force it through.
I was wondering what could be happening to do this. Im guessing either a bent crank or a bent piston arm.
I want to take the motor off but i dont want to touch the carbs. can i change the crank shaft or arm in my drive way and if so where do i go from taking the flywheel off.
thanks
thanks
