How to go from 11" Dia. to 13" Dia.
sportyinc
I purchased a V176 Glasstron with a 115 HP L6 Merc.
I haven't installed a tach yet but I'm worried about the prop.
I measured the prop on the motor and it is 11"X21P.
It is also pretty dinged up. I know how to rate different pitch props, but I don't know how to adjust for the different diameter. Even if I had a tach, the prop is too banged up (IMO) to give an accurate reading.
The manual say this motor takes a 13" prop.
What would be a ballpark equivalent in 13" Dia. compared to a 11"X21P prop?
I'm seriously considering a 4 bladed Alum. prop.
Thanks in advance,
sportyinc
steelespike
Re: How to go from 11" Dia. to 13" Dia.
Did you measure diameter from the center of the bore to the tip of a blade and double it?Or was it stamped on the prop?
See if you can get the prop repaired and get a base line test of the max rpm and speed. Its important to have a tach and gps to get the best idea of what you need and to tell if the selection is right.hwsiii has a form with the info he would need to help you select a prop.See if you can find it in one of his posts.We also need the details on your boat weight,style,Deep V? etc.
sportyinc
I measured from the center of the prop shaft. It is 5-1/2 from center to tip of blade.
The number on the prop: 48-32746A3 21P indicates a 13"X21P Aluminum propeller.
So obviously, this is a prop with A LOT of wear and tear.
Instead of putting more money into this prop, I think I will buy a new one and test it.
Now I just have to rent a torch to get the old one off.
steelespike
Have you tried PB Blaster to loosen things up sometimes works.
I guess we can assume the prop has been there all along and worn out.
obviously no sense repairing.
henrye718
JB weld and some sand paper might fix it enough to get a 2 min test run.
Piranah props has a blade exchange program I dont think you can go wrong with it, they let you test for the price of shipping.
See the link it explains the program...
http://www.piranha.com/exchange.php
