Rotorfixer
Thread starter- Joined
- Aug 10, 2008
- 193
Re: How to install a SMARTCRAFT system
Sorry for the delay!
there is a connector for the paddlewheel sensor, you would need to follow the fuel/ oil/ paddlewheel harness from your engine into the boat, there will be an area of the harness where all of the connections are made, that is where you should find the connector (flat, 4 pin??) you need the paddle wheel sensor to have troll controll based on speed, you can still use troll control based on RPM without it (speed is much better! ie. up/ down wind compensation!)
Hope this helps,
Peter.
Hope this helps,
Peter.
