How to Install Analog Oil Pressure Gauge for Yamaha F150
Ernest T
Hi, I eventually want to upgrade to the Command Link gauges, but they are too expensive for now. My boat has Faria analog gauges, but did not come with an oil pressure gauge. How hard would it be to add a Faria analog oil pressure gauge to work with my Yamaha F150? Here is the gauge that would match my current gauges: http://www.iboats.com/Chesapeake-Wh...55966544--**********.400563091--view_id.87805
Thanks!
rodbolt
Re: How to Install Analog Oil Pressure Gauge for Yamaha F150
you dont.
trust me the ECU will monitor the oil pressure and alarm you for any over or under pressure at any given RPM.
if the pressure doesnt met the ECU map value for any RPM it alarms,and goes into RPM reduction.
Ernest T
Thanks for your reply. Where is the alarm located? In the remote control?
Thanks!
rodbolt
the horn is located on the keyswitch panel or in the 703 box.
the ECU doesnt care it will react regaurdless of if a horn is even installed.
Ernest T
Hey man, Thanks for your help. You saved me a few $$.:)
