How to install restrictors crossover intake manifold
erick11s
Hi, How is the correct way to install the 4 units of restrictor crossovers that is coming with the gasket felpro for my engine 454 rectangular??????
Thanks in advance
Erick
tpenfield
Re: How to install restrictors crossover intake manifold
I have done the oval port type on the 454, but not the rectangular . . . assuming they are the same sort of thing . . .
2 restrictor plates make a sandwich on each side of the gasket. Then there should be some tabs that bend to hold the plates in place. So, you have 4 plates that get installed 2 on each side of the manifold over the crossover port.
erick11s
Thanks a lot, i will do
