How to install telltale on tohatsu
Beevo
I have a 40 hp tohatsu motor that does not have a telltale is there away to install one if so can you give me some instructions and maybe a picture
Sea Rider
Water indicator port/hole is usually located at back right lower pan as seen from engine's back, right under rear cover.If it's clogged won't see engine peeing..
Happy Boating
Beevo
Mines a older motor
Beevo
Ive looked from one end to the other it dont have a telltale mines a 40can really need to figure out how to install one here's pictures of motor
pvanv
See p4 of your owner's manual. non-electric models may not have had the check port standard.
Beevo
Mine is electric start remote steering does anyone have a picture of where the water comes out and goes to the telltale so I can add a telltale to my m40c
Sea Rider
It's not as simple as one might think, for that, must drill a portion of the lower powerhead to add/insert a small tube & small hose to powerhead or cylinder head water circuit/passage. Need to drill a same size hose diam hole on lower pan for other side of hose to exit there Too complicated. How about installing a heat sensing unit to monitor, something that shuts CD off if cylinder head temp passes above its working temp ? Something like a thermo fuse attached to cylinder head could work. Ingenuity and creativity are limitless...
Happy Boating
Sea Rider
Correction, there isn't a exit nipple & water hose on the crank case or adjacent areas in newer 40C. so must have a factory cast inside/outside middle leg water peeing port, same as the 18 HP model. In older 40C it's Mission Impossible installing one.
Happy Boating
Sea Rider
Newer 40C models have a built in internal peeing system that pees through upper left mid section.
The only possible way to install a peeing port would be removing cylinder head, drill a hole on right water path side, insert a tube that has 2-2.5 mm internal diam, connect a hose, drill same size diam hose hole on pan for hose to exit. Quite a job. Love doing challenging conversions but limited to some extent.-
Happy Boating
Beevo
Well you go Mr. MISSION IMPOSSIBLE
