how to install the miissing grease fitting Bravo, Alpha
Status
Not open for further replies.
Bt Doctur
locate the center of the pin ,can be done visually
Drill in 3/8 ths of an inch with a #3 drill bit for 1/4 x 28 thread and tap .
using a 3/64 drill bit CAREFULLY drill approx. 3/4 to 1 inch into the housing until the magnet picks up steel shavings.STOP DRILLING. Install grease fitting.inject grease until you see it between the steering yoke and transom.
Bt Doctur
No, never there. probably to save ten cents. after about 2 -3 years corrosion tears the seal out and water starts leaking in by the steering lever.
This mod is best done before the leakage starts. If only slightly leaking a good shot of waterproof grease will stop the leak.
Bt Doctur
a view from a cutaway showing the corrosion where the seal goes . this after only 2 years
Bt Doctur
Can we make this a Sticky?
By doing this one thing before you start leaking water, you can prolong the life if the steering arm seal.
superbenk
I imagine this has ramifications with warranties. Worth considering if you happen to have a warranty still. Probably worth holding off until it expires.
Status
