Yegboats
Thread starter- Joined
- Feb 20, 2016
- 527
When you install the garboard drain in the picture it doesn't go all the way to the other side of the transom how do you prevent water from damaging the transom? Is there another type of tube you install behind it and seal in?
I would think that the plugs should look similar to the plastic type plugs that go all the way through the transom covering all the wood inside the hole.
