Should be a stainless steel hose clamp item numbers 16 or 18,It's an alpha one drive bolted to a late pre alpha pre alpha transom assembly
| 16 | 54-815504412 | CLAMP, Worm Gear, WATER HOSE |
hose installed fully and clamped tight?
I had to get into the water to reattach it.
underwater? hard enough to see the clamp out of the water
I bought a Quicksilver transom kit last year and installed it. It came with a generic 5/8 heater hose like you mention and a molded 5/8 hose. I installed the molded hose. Maybe the generic hose is too short?Did mercury use special hose in this area? The one on there is just auto grade 5/8 heater hose.
