How to know if engine is charging battery?
matt194
I was wondering how to know for sure the engine is charging the battery. I have done all the test on the charging components but I didn't know the battery was hooked up to the output of the charging system. Is the battery being charged through the wiring harness? Please help
SgtMaj
Re: How to know if engine is charging battery?
You can find out via a multi-meter accross the terminals with the engine off, then on.
Vic.S
The really sure way is to connect an ammeter in series with one of the battery connections, but NOT if you are starting the engine electrically (You don't say what the engine is !) If you are then the ammeter will have to go in series with the output of the rectifier.
It is easier however to do as SgtMaj suggests and connect a voltmeter, or a multimeter set to the 20V DC range, across the battery. It should read something like 12.6 or 12.7 if the battery is fully charged and been "resting" for 12 hours or so. You'll see the volts fall well below that figure while the engine is cranked on an electric starter but it should then rise again quickly if the battery is being charged to something over 13.6. To get the battery fully charged (or at least to about the normal 80-90% of fully charged) you've got to see it rise to around 14-14.4 volts
F_R
A bit of tehcno trivia...A battery is charged by forcing an electric current to flow backwards through it from the normal (discharge) direction. In order to accomplish that, the charge voltage must be higher than the battery voltage. That is why you can detect it with a good voltmeter. Any voltage reading over the basic battery voltage means that at least some some charging current is flowing.
jtexas
you also asked "Is the battery being charged through the wiring harness?"
yes.
the rectifier is connected to the battery (+) cable at the starter solenoid.
