Re: How to locate cyl#1 trigger under flywheel Force125?
It may back fire if the wires are not connected correctly. The wiring for the ignition system on the 4 cylinder 125HP motors can be a nightmare, especially the 1988 - 1989 motors. The wires usually have a small number taped on each end. If they've come off, that can be a problem with the trigger. The wire colors for #3 and #1 cylinders are the same. so without the numbers on the ends, it's kind of a guessing game which is which.
