how to make a DVA adapter for multimeter
F_R
Re: how to make a DVA adapter for multimeter
As long as it does voltage you should be good to go.
Yes, that is the whole purpose of the adapter--to store the voltage pulses so you can measure the peak value. An ordinary voltmeter cannot read and measure the pulses because they are too fast and separated by relitively long periods of no voltage. The capacitor stores a whole bunch of pulses till it is charged up to the peak voltage. Then you read the (peak) voltage stored in the capacitor. Very simple if you understand how capacitors work, otherwise a head scratcher.
huntxtrm
went to neighbor hood radioshack. the closest cap they have is 23uf at 250 wvdc. Close enough? you say my digital with data hold will work without one of these, correct? I still gonna build it, already have all the parts except cap.:D
bktheking
23 will work but it needs to be 400VDC. If you can get 47UF in 400V get 2 and wire them in series, it will 1/2 the capacitance so you get 23.5 uF.
F_R
250 V is too low in theory because you will be applying around 300V or more to it. It might work awhile if you are lucky, but it is teetering on the edge. Like driving a ten ton truck across a bridge rated for 9.5 tons. Might make it if you hold your breath. On the other hand, a cap rated for 600V is better yet.
bktheking
True, that's why is said 400 minimum, aren't watching the SB F_R?
New Orleans won the toss!!
F_R
Wrote the last before it started. Half time now. Later.
bktheking
I called that convert, I had a debate here at home, I knew it was good for 2- it was a good catch.
Good for New Orleans!
huntxtrm
been lookin for a 23uf 400wvdc cap on the internet, can't locate one. any ideas where to buy one?
huntxtrm
and by the way New Orleans Wins! Awesome!
huntxtrm
Ok, looking back into the post and parts list, says 22 micro farad 400 wvdc cap, is that the a 22 uf of 22muf cap? I aint that good with electronics, is that whats tripping me up?
huntxtrm
make sense now, thanks for learnin me something. tried the link you gave they seem to sell in quantities only, but now I know what I'm lookin for. Thanks
ezeke
No, they sell small orders - just add to cart and check out. Shipping will be high.
bktheking
22 would be too large, i'll have to rewire mine with 2.2, thanks for pointing that out Ezeke.
F_R
Aha! I thought there was something strange about wanting a 22mfd there. That's why I questioned it. A 22 would hold a lot of "juice" at 300V. Knock you out of your BVD's if you touch it.
bktheking
Yup, you were right F_R- not just the shock but the timing as well, too large a cap would increase the time it took for the voltage to change.
I am going to redo the diagram tonight so it reflects the proper cap, the change to the one I built should take minutes, cut the old caps out and solder in the new.
Vic.S
Glad that's been revised to 2?2 μf instead of 22 μf. Like FR I thought it was rather large.
Still seems large at 2?2 μf. Seriously wondering if it should be ?22 μf.
