I had to drill a 1" hole in my transom for the transducer plug. I hated to do it but it was the only way. Now I need to figure out how to plug the hole, in a semi-permanent way, in case I need to change out the transducer at some point. I tried to fill it with 5200 and cover it with duct tape while the 5200 set up, but it didn't work out. The hole is 8" above the water line, but the wave that hits the back of the boat when I come off plane is high enough to get water in there.
At this point I am thinking maybe a rubber plug, like you would see in a lab beaker, that has a hole in it for the wire. If I can find one the right size I can put a slit in it to get the wire in then 5200 or 4200 the slit, hole for the wire, and around the plug, when drive it into the hole tightly. Problem is finding that plug.
I am open to any ideas.
Thanks,
Chris
Thanks,
Chris
