How to read RPM with a mulitmeter???
BigBassin78
I have a multimeter that will read RPMs for a 4, 5, 6, 8, cyl engine, presumably 4 strokes, and I want to read the RMPs. Is this possible and if so, what point to I need to touch my leads to in order to properly read RPM. I am trying to tune a new Tachometer.
BigBassin78
Re: How to read RPM with a mulitmeter???
Let me clarify my engine, sorry. 78 Evinrude 115, at what point on the engine do I need to touch the leads to to read RPMs.
nwcove
not 100% sure, but shouldnt you be able to connect to the same leads that feed the tach?
wilde1j
I think you have a 4 stroke dwell/tachometer, and if so, sorry it won't work with an outboard. You need a tach that will work off stator / reg/rectifier pulses.
jimbo_jwc
Ship Happens
Number of lobes on mag pu per revolution /meter on Hz and divide , must be able to get on mag leads
Chris1956
Bigbassin, Your multimeter was designed to display RPM for a battery/coil/points distributor ignition system for a 4 cycle automobile engine. If your OB has a battery/coil/points ignition with a distributor, it may read accurately. That motor will be a 4 cylinder 2 cycle motor, so read it on the V8 scale, if it works at all
F_R
He has Mag CD. Needs an alternator tach.
Bassin, if your tach is an inductive type, it will work, but I highly doubt that is the case because of the # of cylinders choice.
