How to refill gearlube Suzuki DT60?
heze
Hello
Does anyone how I can refill the Oil in the gearcase of the Lower Unit of a Suzuki DT60? What is the right procedure?
Thanks for your answer!
Regards Hendrik
deejaycee_2000
Re: How to refill gearlube Suzuki DT60?
the motor needs to be tilted down as normal drive position .... first take out the top oil plug, then get, your gearoil bottle and nozzel ready, then take the bottom plug out and quickly insert the gearoil bottle at the bottom and squeeze it untill the oil start coming out the top hole ...... then put the top plug back and then the bottom one as quick as possible, after a little while, take the top plug out again and squeeze some more oil in untill it overflows, so that you know it is full, it is messy at times but you'll get over it ......
