How to remove paint overspray from windows???
scrit9mm
Re: How to remove paint overspray from windows???
glass... use a razorblade.
MercMe
Gas will work too but if the windows are plastic they will fog and not be clear anymore. You can all way go old school and use a razor blade.
Sorry I missed in the thread where it said they are plexiglass. Forget everything I said.
jdlough
Master Chief Petty Officer
I've had reasonably good results using WD40 and slowly, carefully using a credit card for the scraper. (Actually it was a grocery store "bonus" card, but you get the idea)
Probably letting the WD40 soak overnight to penetrate and soften the paint would help.
island mike
Wow! an overwhelming amount of replies!
Some of you guys are really funny too..
Some still asume the windows are glass..also pretty funny.:facepalm:.
Thanks again everybody for all the replies and the good tips. I just give all of em a try see wich one works.:D
I will start with wd40 first cause thats what I have lying around.
Regards Island mike
boatman27
Compound and a scratch pad...one that says "NO Scratch"....you can also use Liquid Ice Detailer and scratch pad....it is safe on glass, plastic, rubber, etc....good stuff
island mike
Thanx again evrybody..
Regards Island mike
marioc
I own a window tinting business...
If it's glass, yes use a fresh razor(such as from Home depot-small 2 inch wide with holder).
But anytime you use a razor on glass, you want to make sure you have slip agent. Whether that be water or window cleaner, etc... You never want to run a razor across dry glass. Slip "lubricates" so the razor does not scratch the glass.
Also, for plexi, the best thing to use would be a plastic razor(car detailing type-any professional paint/car detail store has them). Similarly, use slip solution(glass cleaner, baby shampoo dilute in water)...
Hope this helps...remember, never run the razor on dry glass! No need to use WD-40, etc...
Mario
island mike
Thanx,I will give that a try.
Regards I mike
boatman27
Good info marioc....I agree...gotta make sure to keep it wet and ( or ) lubricated.
Glad to hear I been doin it right for years now...LOL
oops!
if you do scratch the glass......a quick swipe with a buffer and lambs wool seems to work.....i have removed several scratches from windows that way....
i hope its the right way...lol......but it works for me
marioc
Glad to hear I been doin it right for years now...LOL[/QUOTE]
Me too!!! LOL
