How to remove this bearing
mjf55
Awesome , sounds like a plan.
Now I need to just get the Mrs. outta the house for a few hours as I am sure that will stink the kitchen up a little bit .
Thanks for the tip !
Tell the Mrs to buy a new outfit. That will get her out.. ;-)
Redrig
Bam ! Who needs special tools ..... Good ole oven worked like a charm !
30 minutes at 450 dropped it about 90 percent , it was hanging by a thread , quick little tap and it was out
Faztbullet I owe you a beer
jerryjerry05
You can probably get the seals out without damaging the bearings.
Just don't score the seal mating surface.
Redrig
yeah , seals were a piece of cake once the bearing was out .
That end cap is all put back together and sealed up now, a perfect sized socket made the seal and bearing install a breeze.
THE BEEF
Go to harbor freight and get a blind bearing puller, there not expensive and you will have a tool to keep, I got one for Christmas and pulled a roller bearing out of the back side of a outboard motor . It worked pretty good. It comes with 3 different size pullers a slide hammer and case. I don't buy many things from them but they do have special tools that you might use twice in a lifetime and there worth it.
Just my 2 cents
