How To Remove This Prop Help Needed
collarobo
I have a 2004 Yamaha F115 it has a 4 blade prop and I have no idea how to remove this prop. There is a black plastic cap as you can see once its is removed there is no nut and no cotter key. It looks like I need a puller or spanner wrench,,, I am trying to remove the prop as I think I spun the prop, I have never had the prop off as I just purchased the boat a few months ago and my motor reves up high RPMS and doesn't go anywhere I had a lose of power while moving in the water and all of a sudden it felp like a slipping clutch if anyone can tell me how to remove this prop I would sure appreciate it.
cwella
It sounds like you may have a spun prop hub, especially with the high RPMs and little to no forward movement. On a Yamaha F115, the prop is usually held on by a prop nut and washer behind the cover, so check carefully for a hidden nut or retainer setup before using force.
My advice would be to avoid damaging the prop or shaft and have the prop checked by a prop shop if you’re unsure. They can confirm whether the hub is spun and rebuild or replace it if needed. Also inspect the prop shaft area while it’s off for any damage or fishing line wrapped around it.
flashback
don't know what brand of prop you have, but I've never heard of one that doesn't need a nut to hold it on. some one has been buggering it.
collarobo
as you can see in the pictures there is no nut and there is also no hole in the shaft where a cotter key would go,,, when I pulled the cap off I am looking at the shaft and the threads look fine the part that has me puzzled is no nut and no hole for a cotter key if there was a nut
cwella
It does sound like a spun prop hub based on your description. If you can share a photo of the prop after removing the plastic cap, it will help identify the retention system and the correct way to remove it.
Dude, the OP posted a pic, did you not look?
jimmbo
Ditto on the Security Nut on the Prop, a real pain when you don't have the Key.
I really am not fan of these, as there is no locking of the Prop Nut preventing it from backing off on its own,
