kinaiahi61
Thread starter- Joined
- Nov 10, 2012
- 215
Aloha,
I am about to fix my boat for the second time (2001 14' Livingston twin hull) . These photos are prior to the last fix. I glassed 2 layers on of 1708 nytex. It lasted for a bit, but I was out on a rough day and had to fly back to the harbor. That did it. It cracked all where it was repaired and then some. I was planning on doing a couple of layers of 1708 inside and a couple outside. Should I go all the way over the middle hump and tie into the floors or just do around the corners. Since the crack is all the way through on the 90 degree of the hull should it be ground all the way out? Should I gelcoat or paint the outside. I will be using laminating resin and 1708 nytex. Any input is appreciated. This boat is run hard so the best, strongest fix would be ideal.
