Re: How to replace Johnson 60 HP Lower unit 1993
There is a combination bolt/pin underneath the bottom carburetor. It's accessable from the port side of the motor. If memory serves me correctly, it's a 3/8" head. A 1/4" drive socket with a long extension is helpful for getting it off & on. When reinstalling the gearcase, the bend in the top of the shift rod "leans" forward. A pair of 11" long needle nose pliers are very helpfull for re-installing the shift rod to the lever. Use the to grip the rod from underneath the lower pan.<br /><br />-John
