DamianJP
Thread starter- Joined
- Mar 25, 2008
- 612
Hello again
I just got a Actron digital timing light for my arsenal of tools.http://www.actron.com/product_detail.php?pid=16315
I have the Tohatsu manual for 1 and 2 cylinder engines.This is my first time using a timing light.
I'm prolly going to feel abit dumb when I get this done but I need a general walkthru and want to do it right.
I wanted to to check and/or tweak my idle and in gear RPMs into spec.
For the 3.5B2
Manual says...
*Turn the running adjusting screw one turn clockwise and start engine.
(1 turn from what postion?)
*Return thottle lever to its closed position and adjust screw until speed is correct. Turn screw clockwise for + speed and counterclockwise for - speed.
NOTE:How can I get a reading of the flywheel to obtain RPMs? Seems blocked by starter recoil assby?
For the NS5B
Manual says...
*Tighten pilot adjusment screw slightly, loosen it to adjust to the standard setting. Set RPM by regulating the throttle and stop screw while monitoring the engine speed with a tach.
(Does that mean tighten it all the way slightly? And how many turns out is standard setting?)
*Set pilot adjust screw to a position where the engine speed is highest within _+ 1/4 turn of the reference position.
(I'm lost, need help)
*Set the specified speed with a throttle stop screw.
NOTE: Set carburetor pilot adjusting screw with clutch on.
Thanks again,
DamianJP
For the 3.5B2
Manual says...
For the NS5B
Manual says...
Thanks again,
DamianJP
