How to set point gap ?? 4.3 mercrusier
Bt Doctur
the strip is for continuity as long as the other spring connection is good you should be fine
al0311
Okay guys did some tests today I started from the beginning again. When out and got a remote bump starter so I can see better for spark. I tested the coil with the high tension wire connected to a spark plug tester and to ground. When cranking I did not see any spark. Next I tested the points. I opened the points by turning the motor over by hand till the point were wide open. I inserted a matchbox for insulation. And ground the coil wire as before. And used a jumper wire to the moveable arm on the points to the base plate. At that time I turned the key on and moved the wire up and down no spark. I also did it while cranking and had no spark. Per the Manuel it is saying a bad coil or condenser ? Doubt the condenser cause I just replaced it.
Also just for kicks I ran the jumper wire to the postive coil to see if anything would happen and still nothing with cranking.
I also attempted to measure the ohms in the resistor. I’m not sure if I did it properly. I removed the wire from the coil to the resistor then measured. The readings were very all over when ever I would move or just the voltmeter leads.
But in anycase. Is it safe to say it’s the coil? Or is there any other tests I can run ? I don’t want to just throw parts at it.
Thanks
al0311
Okay so I did another test one similar to this video https://youtu.be/5kvj_d72WTo well needless to say I got spark from the coil to the light tester. Sooo now what. I also tested with the coil wire on top and touching the test light to the tip of it. I got a small spark every time I flicked the switch and touched the test light. I also tested the volts with it on and the reading was same as the battery. So I’m kinda at a lose now .
