how to shift gears?
guywithboat
Before you chuckle, I am still a newbie....I am working on a 1972 Evinrude 50272C, 50 hp, 2 cylinder. Where do you hook up the gear controls???
F_R
Re: how to shift gears?
Unless I am mistaken that is an electric shift and you don't hook up a shift control cable. It takes a push-button control and it's done by wire.
F_R
blue and green. It sounds like you are stumbling around in the dark, trying to cobble something up without the proper remote control. Am I reading you right? Good way to get into trouble.
guywithboat
yeah your right....poor man, got the motor for 100 bucks....
I have a green, blue and a grey and a purple . Do you know if the push buttons are momentary or "click" on and off? Also, do they use a common ground, which is forward and which is reverse and neutral? Is it in neutral by default? Anyone.....
dsinger
NO power it is in forward.. Also need a set of monkey balls in the control to keep the motor from jamming into forward when you kill it. monkey balls are a dioid one in the controler and one in the motor.
guywithboat
dsinger,
Thanks. I don't think I can make any monkey balls for the controller...don't have enough info.
F_R
Speaking of monkey, if you are going to be monkeying around with this thing get a service manual. It is too complicated to explain one step at a time over this forum. I know they sell them here at iboats. You can also get a genuine factory service manual reprint at http://www.kencook.com/evinrudejohnsonmanuals/ It has a very good wiring diagram and explains how everything works.
