How to start Mercruisr 2.5 L motor
liusigou
Today I pulled mercruise 2.5 into water. To my surprice, I can not start the motor. I am sure the battery is full of the energy.
I am new to mercruise motor. Can you guide me how to start?
Do I need replace the spark? What special tools should I use to take off the spark?
Thank you
liusigou
When we tested 2 weeks ago, the pre-owner was easy to start it. mayby I was wrong
achris
More fish than mountain goat
You can start a car? Boat engine is the same, just open the throttle a little as you crank... Once the engine is running, pull the throttle back to idle.
Chris...
With boat in the water or connected with muffs
One full throttle movement to set choke and prime the carb
Push button on controller to operate throttle only and move throttle to about 30%
Turn key
When motor fires, back off RPM to 1500 for about a minute
Then return throttle to center, then move into gear and go boating
Suggest you take a safety course and have a boat savy friend along
thumpar
Have you checked anything since the last time it ran 2 years ago? They need maintenance. Carbs and points ignition need to be gone over.
