bob johnson
- Joined
- Feb 25, 2009
- 4,306
last year i set up a dual battery system in my boat. with the battery switch and a Guest battery charger. I left the switch on "BOTH" for a month and a half after my last striper trip. this weekend the batteies were dead...
no problem, I figured there may be a slight draw in the boats wiring, so i plugged the onboard charger in and the next day went to check the boat. the batteies were still dead!!
i leaned over and sure enough the little green light on the charger was on....telling me the charger had power!
so I unplugged that charger and I plugged in my sears battery charger. It has a % reading and several other options for charging...its a nice charger... i selected deep cycle and 6 amp charge power and set the one scale on %. the % at the start was about 5%....after 5 hours or so the % was up to 65%, I did this for each battery one at a time...they both didnt seem to want to go past 65%
in the last few years these batteries always went to 100% when used with the sears charger. As well during the last year the onboard charger has never let me down... i plug it in the night before i use the boat and I always had full power the next morning!!
so now i want to see if the onboard charger is working...or if it some type of bad connection in my wiring contacts...or if the batteries are going bad and the charger cant charge them for some reason
how do i check the output of the onboard charger?
on another note....since the sears charger wont charge past 65%, is that telling me the batteries are dead....one is only 18 months old... a big interstate deep cycle I bought at the marine mechanics
thanks
bob
thanks
bob
