how to test my stator ????
johninmo
I called the shop and he said it sounded to him like the high side on my stator was bad he said if i brought it by he could test it can I test it at home I have a meter that measures voltage and ohms
thanks
achris
More fish than mountain goat
Re: how to test my stator ????
You'll need an adapter for the meter... Click HERE for details on how to make one.
Chris.........
bryanwess2000
Before you go to the trouble making a dva, disconnect all the leads from
switchbox, rectifier, and ground. Check resistance from blue to ground
and red to ground and post up your #'s. I don't have my manual in front of
me but if noone's post up I'll list the normal ranges.
achris
This subject has been done to death... Resistance is NOT a valid way to verify ignition system components.
Chris.........
bryanwess2000
I know it's not a thorough check without a direct voltage adapter but
if the resistance is out of spec on the high speed coils, he can tell with
his VOM. If they break down at a certain rpm range then yes he'll need
a DVA. I'd start with the ohm readings and if need be check while running
with a DVA. To each his own. I've found 2 bad V6 stators by ohm readings
alone. I was just trying to save the guy some time and effort. I do however
agree that you need DV readings to thoroughly check the ignition, thats
why I own one.
bryanwess2000
Stator #s 398-8778, 398-9710 high speed coils 75-90 ohms, low speed
3250-3650ohms. Does your motor cut out around 2000-2500rpms?
johninmo
sorry I havent had the time to test that yet no cutting out but it did make a noise a few times kinda like I had it trimmed a little high but it was all the way down I also found after further inspection of my plugs it seems there is a piece of metal(aluminum??) on the end of my #1 plug touching the electrode could this have been my problem all along?
achris
Oh dear.... That sounds like a piston has detonated. If so, an engine strip and rebulid is the only fix.
sschefer
Or a broken reed... Sometimes you can see the damage through the plug hole but if not, borrow a bore scope and have a look. achris is right, it aint gonna be good considering your qualifying symptoms.
